Problem with Javascript Code (Live Help Button)
9 replies to this topic
#1 Guest_isphttp_*
  • Guests
Posted 21 November 2008 - 11:01 PM
i have a Problem with Include the Live Button with Tracker, my CMS Tell me a Syntax Error:
Parse error: syntax error, unexpected T_STRING, expecting ',' or ';' in /var/www/web151/html/themes/isphttp/theme.php on line 332".
ISPHTTP Live Support Chathttp://www.LiveZilla.net Tracking Code -->
can someone help me?
is possible the Tracker include without the Live Support? so i can the Live Support with Iframe embed without Problems.
Best Thanks for Help, sorry for my Bad englisch ;)
  • 3854 posts
Posted 22 November 2008 - 08:25 AM
As you said, this is HTML code. But you seem to place it into your php code. :(
If you want to use PHP please use this code: (" must be masked = \")
echo "\"ISPHTTP
#3 Guest_isphttp_*
  • Guests
Posted 22 November 2008 - 10:41 AM
Thanks for Answer, the Themes.php is for the Layout and 70% html, 30% PHP:
	echo '
VServer XXL 30 GB Speicher HDD 512 MB Arbeitsspeicher 400 GB Traffic inklusive Eigene IP Adresse 64-Bit Dualcore CPU Reboot & Neuinstall VServer Control Panel SSH Root Zugang 14 OS IMAGES RAID 1 System Logical Volume Manager 100MBit Anbindung Garantierte Leistungen Mehr Details Jetzt Bestellen *Vertragslaufzeit 3 Monate. Preise inkl. MwST.
the livesupport.php is with Iframe "the javascript code". this works finde, but the Tracker not works, and tell me from visitor "livesupport.php".
i include your Code, but the same Problem:
have you a other idea?
Best Regards
#4 Derek Punzova
  • 6181 posts
Posted 22 November 2008 - 12:16 PM
The code you provided does not contain the LiveZilla Tracking code.
I would recommend to take your time and learn some PHP basics. Maybe its also useful to google for "Anführungszeichen maskieren + PHP".
#5 Guest_isphttp_*
  • Guests
Posted 22 November 2008 - 12:28 PM
 echo '
echo "\"ISPHTTP
Thanks for Help, but code with the masked Code from pkeil not works, included iin Themes.php ;) you know what i mean?
#6 Derek Punzova
  • 6181 posts
Posted 22 November 2008 - 01:02 PM
Well, you place an echo command within an other echo command.
It seems that you have no idea of the difference between php and html.
I can only recommend to learn some PHP basics, especially echo and masking once again.
#7 Guest_isphttp_*
  • Guests
Posted 23 November 2008 - 01:01 AM
Thanks for Help, i have the Problem fixed;)
This is the Best Live Support Chat Scrip :mrgreen: Good Work
#8 Derek Punzova
  • 6181 posts
Posted 24 November 2008 - 02:32 PM
Well done :D
#9 Guest_tulipa_*
  • Guests
Posted 10 December 2008 - 01:27 PM
How can I find the javascript in computer to be turned on? When I go to see a movie or a video or even to download pictures it says that my javascript isn't on. So I tried to find the java but dont know where it would be located to be turned on. I do really want to look at videos and pictures of my family.
#10 Patrick Keil
  • 3854 posts
Posted 11 December 2008 - 07:39 AM
This may help:
http://jumk.de/javascript_e.html
http://www.renesas.com/support/guidelin ... script.htm
