Input fields not always being saved in DB
3 replies to this topic
#1 JayMan
  • 25 posts
Posted 12 February 2020 - 04:01 PM
Version 8.0.1.7
I've attached a file to show it. The DB doesn't show the input fields for all chats. If I go into the archives and select one of the chats the details window is grayed out.
I need to know how to fix this because we need to have those input fields captured all the time.
I did an upgrade from V7 to V8 2 weeks ago.
  • Attached Image: Annotation 2020-02-12 105505.png
#2 JayMan
  • 25 posts
Posted 13 February 2020 - 08:00 AM
I just went to look at a V7 copy we have and it does the same thing. The input fields are not always captured in the DB. No pattern that I can see to cause this.
#3 Patrick Keil
  • 3883 posts
Posted 14 February 2020 - 08:06 AM
This is not a known problem.
Can you provide detailed step by step instructions explaining how to reproduce this issue on our side?
#4 JayMan
  • 25 posts
Posted Yesterday, 04:40 PM
View PostPatrick Keil, on 14 February 2020 - 08:06 AM, said:
It's ongoing, normal chats going on. Not sure how else to reproduce it. Both v7 and 8 are doing it. Is it possible it is caused by someone either the support agent or the customer using the end chat function .It seems very random and I cannot pin down a pattern to when it does or doesn't save the chats.
This is a screenshot from chats taken so far today. You can see where the input fields are not always populated.
We have 10 custom input fields all set to mandatory.
  • Attached Image: today.png
