I need to add LiveZilla users to CRM automatically, maybe through Zapier?
3 replies to this topic
#1 imonline
  • 2 posts
Posted 27 June 2018 - 12:19 AM
I'm starting to use "nocrm . io" as my business CRM and have been able to add leads automatically from my website forms, email, twitter, facebook, etc. through Zapier.
But I can't integrate LiveZilla because it's not one of the Apps Zapier supports.
Does anyone know if we can integrate LiveZilla with other programs such as CRM automatically? Or even better, is there a way to add LiveZilla as one of the apps supported with Zapier?
Thanks!
Sergio
  • 3817 posts
Posted 27 June 2018 - 06:21 AM
Hi Sergio,
Did you check our LiveZilla Data API?
You can connect LiveZilla with any 3rd party application.
#3 drethan
  • 17 posts
Posted 17 July 2018 - 01:48 PM
Zapier supports creating a HTTP POST and since LiveZilla's API is just a POST to your installation URL then its definitely do-able. Biggest thing would be how to pass your sensitive information through Zapier safely.
** Depending on your LiveZilla setup I think you could actually just statically set your p_user and p_password in your HTTP POST Body within Zapier. Just make sure you md5() the password beforehand.
#4 imonline
  • 2 posts
Posted 28 August 2018 - 10:02 PM
Hi Patrick and Drethan,
Thanks for your replies. I will check the LZ Data API and HTTP POST in Zapier.
I'll post an update if I can get this working with or without Zapier.
Thanks!
