SEO friendly knowledge base URLs
12 replies to this topic
#1 wwwampy
  • 27 posts
Posted 15 June 2018 - 07:56 PM
I've changed the .htaccess file and enable SEO friendly knowledge base URLs, but I still don't see any friendly URLs for the knowledge base.
What am I missing?
  • 3883 posts
Posted 20 June 2018 - 08:04 AM
Thanks for testing this new feature.
Is mod_rewrite activated on your webserver?
#3 wwwampy
  • 27 posts
Posted 20 June 2018 - 08:45 AM
yes, it is activated.
  • 3883 posts
Posted 20 June 2018 - 08:48 AM
Can you provide your livezilla server URL please?
#5 wwwampy
  • 27 posts
Posted 20 June 2018 - 08:52 AM
I've sent it to you via PM.
  • 3883 posts
Posted 20 June 2018 - 08:54 AM
Thanks for the URL. It works fine.
Just rename your ids as described here:
https://chat.livezil...rl-mod-rewrite/
#7 wwwampy
  • 27 posts
Posted 20 June 2018 - 09:00 AM
:oops: sorry, I missed that part:
  • Finally, you can change the ID in each public knowledge database entry
It works great!
Thank you.
#8 wwwampy
  • 27 posts
Posted 26 August 2018 - 05:59 PM
Patrick, one more question.
How can I change the Knowledge base URL (mydomain.com/knowledge-base/) to something else for example mydomain.com/support/?
Thank you.
Regards
#9 Patrick Keil
  • 3883 posts
Posted 27 August 2018 - 06:55 AM
The folder name is "hard-coded" in the .htaccess file, you should be able to change it.
Cheers.
#10 wwwampy
  • 27 posts
Posted 27 August 2018 - 08:48 AM
Thanks, I will take a look.
Btw, can the root folder point to knowledge base? Example, mylivezilla.com points to KB and not to default page like now.
Thank you for your reply.
#11 wwwampy
  • 27 posts
Posted 27 August 2018 - 04:55 PM
Also, I've figured out the redirect in .htaccess, but now I can not use the SEO friendly URL. I change the ID, hit Save, but when I open it I can see the ID is not changed.
EDIT: uh oh, now I see, the URL is too long. But it's not, can you please allow a bit longer?
#12 Danny Streichert
  • 2 posts
  • LocationJ√∂hstadt, Germany
Posted 04 December 2018 - 08:03 PM
Yes, it would be very useful if the URL / ID could be longer. As far as I can see, the cause of the problem may be the limitation of the DB field to Varchar (32). Maybe it would be good if the field were changed to TINYTEXT.
#13 Patrick Keil
  • 3883 posts
Posted 06 December 2018 - 12:38 PM
Thanks for bringing this to our attention.
I have changed this to our list for the next update.
