Write access problems
5 replies to this topic
#1 florentcm
  • 4 posts
Posted 15 November 2011 - 10:06 PM
When I attempt to reach the LiveZilla Server Page, I get these errors :
Write Access:
Insufficient Write Access (./uploads/)
Insufficient Write Access (./images/)
Insufficient Write Access (./banner/)
Insufficient Write Access (./_config/)
Insufficient Write Access (./_internal/)
Insufficient Write Access (./_groups/)
Insufficient Write Access (./_log/)
Insufficient Write Access (./stats/)
Insufficient Write Access (./stats/day/)
Insufficient Write Access (./stats/month/)
Insufficient Write Access (./stats/year/)
:arrow: I already read all the topics about changing FTP permissions, and indeed, my permissions were not good. I changed it through FileZilla. I checked the modifications of permissions with a PHP script which contains fileperms instructions.
:idea: The result of this script sounds good to me :
_config 0777
_definitions 0755
_internal 0777
_language 0777
_lib 0755
_log 0777
banner 0777
docs 0755
images 0777
sound 0755
stats 0777
stats/day 0777
stats/month 0777
stats/year 0777
templates 0755
uploads 0777
:arrow: Besides, I can't use LiveZilla because I can't create a user. I get the following error dur to write access : (500) Internal Server Error. Changes could not be saved.
:?: I think there still is a problem with write access, or maybe LiveZilla don't take effect of the modification.
#2 Derek Punzova
  • 6135 posts
Posted 16 November 2011 - 07:27 AM
Which version of LiveZilla do you use?
Is this shared hosting?
Any PHP security modules running on your webserver?
#3 florentcm
  • 4 posts
Posted 21 November 2011 - 03:45 PM
Version 3.3.2.2
Module Apache mod_pagespeed
It's not shared hosting
#4 Derek Punzova
  • 6135 posts
Posted 21 November 2011 - 03:55 PM
I am not familiar with this module, did you try to turn it off for debugging?
#5 florentcm
  • 4 posts
Posted 21 November 2011 - 07:54 PM
Yes, I don't think it's this module.
I just discovered a few errors in SELinux.
Error for the "uploads" folder I get in /var/log/audit/audit.log :
type=AVC msg=audit(1321890971.527:624798): avc:  denied  { write } for  pid=15718 comm="httpd" name="uploads" dev=dm-0 ino=143323 scontext=unconfined_u:system_r:httpd_t:s0 tcontext=system_u:object_r:httpd_sys_content_t:s0 tclass=dir
I get the same error log for each folder with writing access problem.
How can I fix it ?
#6 florentcm
  • 4 posts
Posted 21 November 2011 - 09:46 PM
Problem fixed with the command :
setsebool -P httpd_unified=1
Found in this thread : https://bugzilla.red...g.cgi?id=472699
