Problem with update of LiveZilla
5 replies to this topic
#1 glennl
  • 48 posts
Posted 05 December 2008 - 06:46 PM
I have LiveZilla 3.1.7.7. installed and tried to update it to 3.1.7.9, but without success.
It starts downloading the new version, then asks to install it and then windows vista comes up with a window to accept the installation, but then nothing happens...
Any suggestions?
I don't want to loose all my settings when updating, is it possible too?
thanks
#2 Guest_Disnak_*
  • Guests
Posted 05 December 2008 - 07:38 PM
I am also having a big trouble with the new upgrade. The system keeps always saying:
"unable to unistall old version of livezilla"
The point is I deleted the folder, hidden folders in "Documents and Settings", cleaned the registry and nothing. I can't install the new version.
Windows XP.
I would appreciate a hand!,
#3 Patrick Keil
  • 3538 posts
Posted 08 December 2008 - 09:57 AM
Did you try to download it manually from our website?
Windows XP.
Thanks
Sounds like a terrible bug in our Install Software (InstallAware). Please make sure that you have administration privileges (run as administrator).
In the InstallAware Forum I found the recommendation to use MsiZap for deinstallation in this case. I am sorry for this annoying problem!
#4 Guest_Disnak_*
  • Guests
Posted 08 December 2008 - 12:12 PM
Hello pkeil,
Thank you so much for your support!.
I did some research about MsiZap and I found a better tool from Microsoft:
http://download.microsoft.com/download/ ... sicuu2.exe
You may want to try it, it's a little program you install and it detects all the msi packages installed in your pc. In my case, there was an old livezilla version, I selected it, then "erase" and worked like a charm.
Next I could install correctly the newer version of your chat system.
Have a great day!.
#5 Derek Punzova
  • 6181 posts
Posted 08 December 2008 - 03:55 PM
Disnak said:
Hello pkeil,
Have a great day!.
Thank you for this valuable information!
#6 glennl
  • 48 posts
Posted 14 December 2008 - 08:04 AM
pkeil said:
Ok, manually downloading solved my problem!
regards
