Using the OverlayWidget in a pre-defined <div>
5 replies to this topic
#1 dbock
  • 5 posts
Posted 13 February 2018 - 08:40 AM
thanks for accepting me in the Forum.
I was configuring and testing LiveZilla the last two days on one of my websites - works good so far. The only problem that I have, is that I want to show the LiveZilla Chat in a box, which shows after the user clicked on a floating button on the right.
Is there a way to say, in which div (most propably using the divs id) the LiveZilla Overlay Widget appears (after using the .show() command)?
Or is there at least a known workaround or some changes which need to be done to the code? (Basically I just want to show the widget in a div, and not at the last child of the <body>).
Thanks for every input or comment in advance.
Regards,
David
  • 3668 posts
Posted 13 February 2018 - 08:55 AM
Hi David,
There's no way to specify a div, sorry.
Why so complicated?
#3 dbock
  • 5 posts
Posted 13 February 2018 - 09:07 AM
The requirements are coming from the customer...the already have the design, and my task is to build it now ;)
Other question: When I use the Floating Button or the Text Link, is there an option to show the chat on the same site, instead of opening it in a new window?
Edit: And they would like to use LiveZilla
  • 3668 posts
Posted 13 February 2018 - 09:44 AM
You can create your own floating button or text link and use the API mode with it.
By doing so, the on-site widget will appear when the floating button is clicked (instead of new window).
Link Generator -> Element -> API Mode
#5 dbock
  • 5 posts
Posted 13 February 2018 - 10:07 AM
But where will the on-site widget appear? Same position as the Default OverlayWidget V2 (as last child of the <body>)?
  • 3668 posts
Posted 16 February 2018 - 12:47 PM
As I said, there's no way to specify a div, it will always be added to the body.
