Don't cache certain input fields
7 replies to this topic
#1 Jonathan
  • 14 posts
Posted 16 October 2017 - 09:56 AM
I try to do the following:
Generate a Text-Link on every product page of my shop.
When following the link, the customer opens a chat window where he can leave a message/ticket.
No problem so far.
As additional information the product name, choosen quantity and choosen options shall be added in a custom input-field.
My first tries with only the product name doesn't work.
For the first product the chat window opens and the product name is filled. For the second product the product name is filled with the name of the first product.
I think it has something to do with the caching of information livezilla does. (Although I disabled the "cookie"-field for the custom field)
Is there any possibility to transfer information to the chat window which changes often in on session?
Kind regards
Jonathan
  • 3698 posts
Posted 16 October 2017 - 10:12 AM
Hi Jonathan,
From the FAQ:
The data pass-thru will only work if the customer didn't already fill in his/her data in the input fields. So the data filled in by the website visitor will always be prioritized.
In other words, Pass-thru works for blank fields and you can't overwrite existing values.
The good news is that we will add a new paramater that will allow you to control this behaviours (overwrite yes/no) in the next update 7.0.8.5.
Cheers.
#3 Jonathan
  • 14 posts
Posted 16 October 2017 - 10:19 AM
Perfect. Looking forward to this update.
What's the paramater "cookie" for then?
  • 3698 posts
Posted 16 October 2017 - 10:57 AM
I don't know yet, but we will add it here:
https://www.livezill...id=passthrudata
#5 Jonathan
  • 14 posts
Posted 02 November 2017 - 03:02 PM
tested the new feature and it works fine, as long the customer don't send any messages.
When the user has sent a message to us the field doesn't get overwritten anymore. Instead the field shows the value used for the message.
  • 3698 posts
Posted 03 November 2017 - 08:02 AM
Thanks for the feedback. We will check.
#7 Jonathan
  • 14 posts
Posted 09 November 2017 - 01:26 PM
Installed the new version 7.0.8.6.. Problem solved.
You guys do a great work! Thank you.
#8 Patrick Keil
  • 3698 posts
Posted 09 November 2017 - 01:51 PM
Perfect! :)
