PageSpeed problem with gzip
3 replies to this topic
#1 Henk1060
  • 3 posts
Posted 07 February 2017 - 08:18 AM
Good day,
I have a problem with the LiveZilla code.
All my js and css will be compressed.
Unfortunately not
Resource.php? T = js & 1 = jscript / jsglobal.min.js & 2 = jscript / jsbox.min.js & 3 = jscript / jstrack.min.js
Resource.php? T = css & 1 = style.min.css
Use an Nginx server with these settings.
And https and http2
gzip on;
gzip_http_version 1.1;
gzip_comp_level 8;
gzip_static on;
gzip_vary on;
gzip_proxied any;
gzip_min_length 1400;
gzip_types text/plain text/css application/json application/x-javascript text/xml application/xml application/xml+rss text/javascript application/javascript text/x-js;
gzip_buffers 16 8k; gzip_disable "MSIE [1-6]\.(?!.*SV1)";
expires 1M;
access_log off;
add_header Cache-Control "public";
How could I solve this problem?
Or is it possible to remove the Js and css from the code and insert this manually into my template?
  • 3806 posts
Posted 07 February 2017 - 08:26 AM
Please note that the LiveZilla resource files are already compressed. You don't need to compress again.
You may want to exclude the LiveZilla folder.
#3 Henk1060
  • 3 posts
Posted 07 February 2017 - 08:39 AM
Hy, Thanks for your fast anwser
This is the Problem
Posted Image
  • 3806 posts
Posted 07 February 2017 - 08:52 AM
There's a confusion between compression and minification. My fault.
You are right, this is a webserver configuration but I don't know what's wrong with your settings.
Our resource php outputs one of these two headers, depending if its's css or js
if($_REQUEST["t"]=="css")
    header("Content-Type: text/css;");
else
    header("Content-Type: application/javascript;");
Both header types are included in your configuration.
